Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Honda Accord V6 Alarm not allowing car to start
Old Oct 15, 2018 | 04:06 AM
Axel Ruiz's Avatar
Default 2006 Honda Accord V6 Alarm not allowing car to start
I currently own an accord. Yesterday I noticed the battery light was on so I tested the battery. Battery ended up not being good along with the alternator. Swapped both out .Now when I go to start the car the car the alarm goes off for awhile .Along with that the green key light is on the dash light. From browsing forums. It seems the immobilzer is getting set off .I don't have a spare key to try. The car does not crank and the starter won't engage when I turn the key. Pretty lost at the moment .I will check the fuses on the driver side and in the fuse box later .I believe that is what I should check. Any help or guidance moving forward will be greatly appreciated.
Old Oct 24, 2018 | 04:40 PM
Cowpoke's Avatar
Default Re: 2006 Honda Accord V6 Alarm not allowing car to start
Did you figure this out? If so, please say so and complete this thread. If not, have you reset your anti theft system after the battery replacement?
sweetcndy25
Feb 25, 2013 10:41 PM
xang0
Jul 5, 2009 09:14 PM
02gixxersix
Jun 27, 2006 06:19 PM
