Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2014 Honda Accord Starter Solenoid
Old Oct 11, 2018 | 07:18 AM
Sigman's Avatar
Default 2014 Honda Accord Starter Solenoid
Hello,
I've been reading through the forums and surprise surprise I've seen a lot of posts about 2013-2017 accord starter issues. My wife's 2014 2.4L 4cl with 133000 miles is having starting issues. I had the battery warrantied and I've replaced the alternator because it was tested bad by AutoZone. It did well for a couple weeks then started sporadically not starting again. I had the battery and alternator tested again and they passed. I'm not sure who can test a starter for free. Now, most of the posts have said to replace the starter which I don't have a problem doing. It looked pretty easy to do, but I had a question about the system. My step-dad, who I ask about car issues, stated that there is usually a solenoid between the starter and battery that could be the problem. I can't find any documentation stating that there is a solenoid outside of the starter. So my question...Is there a solenoid to replace for $20 instead of me buying a $250 starter?
Thanks,
Nick
Old Oct 11, 2018 | 01:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: 2014 Honda Accord Starter Solenoid
Thanks,
Nick
No. There is no solenoid.
Old Oct 11, 2018 | 01:41 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Let me clarify. there are serviceable parts to be sure. There is no solenoid,but the starter can be rebuilt. Ive not taken one apart so I do not know what the fault is,but if you can figure it out,you can replace just that part you need.
If you are mechanically inclined, I imagine they are fairly easy to rebuild(most Honda starters are)
Old Oct 12, 2018 | 05:03 AM
Sigman's Avatar
Thank you. From what I could tell there was no Solenoid on the outside of the unit like some other starters I've seen. If the starter had fewer miles on it I might be more likely to replace a specific part but it already has over 130k miles on it. I'm going to double check the relay and replace the starter if the relay is good.
Old Nov 15, 2019 | 01:44 PM
M S's Avatar
M S
For those having the starter issue, here is additional info. I just had this problem with my 2015 honda accord coupe. Owned 4.5 years, 54K miles. Starter and ignition button had to be replaced at an original quote of $1100 because it was out of warranty. I found all of the info online that this was a known issue (starters failing) with 2013-3015 accords. I called Honda America customer service. After ten minutes of requesting that they start a case file for my complaint and escalate to a supervisor, and the lady refusing, I then stated I would be lodging a complaint with the NHSTB. She then said she’d speak with a supervisor and low and behold I was allowed to file a case. I was called back within two business days and they offered to replace starter and ignition for $400 and give me a new 3 year/36K warranty on it. I accepted, it was fixed this week and I still filed a NHSTB complaint. I’d suggest all people having this problem do so. A lawsuit filed in 2017 in NJ for this known issue was thrown out, with one reason being there were not enough complaints filed to indicate a pattern.
ms.ladyjones13
Sep 24, 2016 09:17 AM
jdmacuraITR
Apr 27, 2014 11:07 PM
accord96lx
Mar 19, 2014 04:02 PM
Waystein
Jun 10, 2004 08:13 PM
