96 lude h22a with f22b2 ecu?
Old Oct 8, 2018 | 03:04 PM
Ty.jon's Avatar
Default 96 lude h22a with f22b2 ecu?
Okay so i was looking at the diffrence in the 37820-pof-903 (h22a) and the 37820-poj-l61 (f22b2) and some of the pins are diffrent. I have a 96 jdm prelude h22a and had some wireing issues witch in turn burnt my ecu. My buddy had a 97 honda accord f22b2 that he was scrapping. So i got the ecu from him and the engine wiring harness to fix problem that cause my ecu to burn up. I was wondering if the f22b2 ecu would work with my h22a? If so is what is the process? I have looked at the wiring and some of the conectors are diffrent. Any help one be appreciated!
Old Oct 8, 2018 | 08:20 PM
TimiK's Avatar
10 Year Member
Default Re: 96 lude h22a with f22b2 ecu?
it wont work.
you need to get chipped ecu or jdm/usdm h22 ecu (with usdm ecu you have to play with electris, change sensors to usdm, distributor, oil pump, intake manifold etc) and with jdm ecu you need engine harness with it
will@strd
Jan 13, 2006 06:48 AM
XLR8_HFX
Jan 8, 2006 09:02 PM
