‘95 Accord ex- manual. 4cyl. vtec
Old Oct 6, 2018 | 04:32 PM
Sam Bowers's Avatar
Default ‘95 Accord ex- manual. 4cyl. vtec
Just recently had to change the lower heater hose (engine to valve). Now that’s done, but it’s been a week and yesterday after driving I noticed a fairly good amount of antifreeze leaking from the radiator somewhere. At the time, all I was able to do was use some radiator stop leak from oreillys. Which did work for the time being until I can get a better look in a better location. So today I decided to just check the coolant overflow and found it is now white in color. Is my only diagnosis head gasket related? Also, if the cars still able to function it would have to be a leak not blown, correct? And lastly, where should I focusing on finding these leaks? Help
Old Oct 6, 2018 | 05:56 PM
GhostAccord's Avatar
Default Re: ‘95 Accord ex- manual. 4cyl. vtec
How does your engine oil look?
Coolant system pressure test would be your best bet to find a head gasket leak. However, this will not work until you have the leak in your system fixed / radiator replaced.
jenq payne
May 20, 2019 05:33 PM
dragonman80917
Mar 9, 2015 11:40 AM
syvlvr
Nov 19, 2012 04:11 PM
Kgill23
Aug 30, 2010 03:14 AM
badazzaccrd
Dec 25, 2008 10:02 PM
