B16a2 Swap wiring dilemma
Old Oct 2, 2018 | 08:08 PM
str8up720's Avatar
Default B16a2 Swap wiring dilemma
The car is a 2000 ex 5 speed. Im in the process of working on the wiring for this swap, and have read i need to extend a few harness wires for some sensors including the rear o2, crank sensor, and vtec solenoid and pressure switch wires. Am i missing any others? I also ran into the issue of my distributor connector being different from the previous distributor connector on the harness. I went and got one from an integra to match it up. As i am re-wiring the harness wires into the new distributor connector, i noticed the black/yellow (ignition input) wire on the distributor is a thicker gauge than the same wire on the wiring harness. will that cause any issues? I am pretty much matching the the same colored wires from harness to distributor correct? Any input from anyone who has done this would be great.
Old Oct 3, 2018 | 08:02 AM
tony_2018's Avatar
Fish Twig
Default Re: B16a2 Swap wiring dilemma
2000 ex 5spd, get the proper distributor adapter, repin crank sensor plug, might need to extend iat cuz b16a2 iat is on the manifold. I think thats it, all I can remember.
Old Oct 3, 2018 | 05:31 PM
str8up720's Avatar
Did u extend the rear o2 sensor or will the wiring reach? Did you notice any of the distributor wires being thicker than the harness wires?
Old Oct 3, 2018 | 07:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is OK to connect the thin black/yellow wire from the distributor to the thicker black/yellow wire in the engine harness. What ECU do you intend to use ???
Old Oct 4, 2018 | 06:43 PM
str8up720's Avatar
im using a p2t off of a si civic
Old Oct 4, 2018 | 08:39 PM
JRCivic1's Avatar
10 Year Member
Community Builder
OP, with the P2T ECU, ^^^ This ^^^ will be a good start. Dizzy adapter (or cut and splice the original EX engine harness), convert the 3 pin CKF sensor plug to a two pin plug, leave your IAT sensor installed and wired in the air inlet tube (and ignore the IAT sensor in the intake manifold itself if it exists on your engine), and lastly... either extend your primary O2 sensor plug or purchase an O2 extension harness and connect to the O2 sensor at the rear of the header.
Old Oct 5, 2018 | 06:47 PM
str8up720's Avatar
Where can i find a dizzy adapter and or 02 extension harness?? As far as converting the CKF sensor to a two plug, can i just cut off the extra wire or even tuck it away..? yea i know its a pretty dumb question but just want to be on the safe side.
Old Oct 5, 2018 | 07:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I wouldn't cut anything there... de-pin the two wires that will be used and insert them into the "B" series two wire clip... then tape back the brown/black ground wire in the event that you ever need to change things back. I know the O2 sensor extension adapters are commercially available, my local shop has them on the shelf. The distributor adapter can also be found commercially or can be "built" by someone comfortable in doing so. If you intend to purchase one, make sure you get the proper gendered ends for both the engine harness and distributor connectors.
Old Oct 6, 2018 | 09:32 AM
tony_2018's Avatar
Fish Twig
need stop with the cutting when there is a way to de-pin or there is a harness available.
Old Oct 9, 2018 | 05:06 PM
str8up720's Avatar
Im not a big fan of cutting wires myself. I feel pretty confident in my soldering abilities. I will tackle this job one of these nights and follow up my results. Thanks to everyone for the advice!
Old Oct 9, 2018 | 07:14 PM
tony_2018's Avatar
Fish Twig
RightOkBye
Haleiwa-Brando
Dec 26, 2007 09:45 PM
BlazeInEk
Oct 22, 2004 04:08 PM
89 CRX SI
27
Jan 20, 2003 04:12 PM
