ALittle help
Old Oct 2, 2018 | 07:10 PM
Rocket1474's Avatar
Default ALittle help
Ok guys I’ve got a issue, d15b7 Honda Civic automatic, I had a naked wire hit my block and grounded my engine out and cut it off, so I replaced my battery-battery terminals-switches-fuses-relays, it was a fan wire that hit the block but still nothing it will not even turn my fans on or fuel pump or anything for that matter, I don’t run a key style switch I run a toggle switch and push button I’m just wondering what the issue can be?this is my dirt track car, it isn’t producing any power to anything at the moment Please any advise would be well appreciated
Old Oct 3, 2018 | 02:49 PM
Turbo1983's Avatar
Default Re: ALittle help
Maybe main relay?
Old Oct 3, 2018 | 02:52 PM
Turbo1983's Avatar
Originally Posted by Turbo1983
Maybe main relay?
also check the rest of your grounds.
Old Oct 3, 2018 | 03:17 PM
sumdewd's Avatar
Did you visually check the fuses in both the engine bay and in the dash? or did you test their continuity with a multimeter? A fuse will not always be visibly broken.
Can you elaborate more on the wiring? Is the rest of the car wired normally? Do any interior lights or lights in general work? I have a hard time believing a single fan wire jacked up the power for your entire car without blowing its own fuse or the main fuse first.
89hondanoob
15
Mar 10, 2015 09:12 PM
blasterman87
Jan 14, 2010 06:49 PM
ever'sneighborhood
Mar 26, 2009 07:46 PM
1BADEGDC2
Sep 14, 2008 04:03 PM
hatchinprogress
20
Aug 14, 2004 05:50 PM
