Radiator fan not working (searched)
To start off I have a 90 crx dx with a b18a1 swap. I noticed my fan is not turning on which explains the overheating sometimes. My question is, what exactly tells the fan to turn on? When I search b18a1 fan switch I get multiple answers/ things to buy.
from what I have read I have located 2 "switches" on the car. One is next to the oil filter on the back of the block (has 2 prongs sticking out with a rubber boot covering it and where the 2 wires connect). The other is on the passenger side under the distributer which from googling is the same one that on some b18s is on the thermo stat itself.
my wiring is a mess and I am having a hard time following where they each lead to. I am going to jump the fan to see if that is an easy fix but it's pretty new so I want to have other options if it works.
Thank you ahead of time and I hope this doesn't turn into the threads that pop up in the search with different answers.
Pull the plug off the thermostat switch, and jump the wires. If the fan comes on with the key on, the switch is faulty. If the fan still does not work after jumping the wires, check your relay wiring.
I have read too many different answers when I search so I just want to know if the one on the back of the block is what my main focus should be on. I just want to make sure that the one near the distributer has nothing to do with the fan and I'm getting somewhere with the clicking relay.
sorry if this is confusing, I hate wiring so I'm doing my best to explain.
Thank you all. All the videos showed the other switch and when I Google it both switches pop up for me to buy labeled as the fan switch. Hopefully I can get this figured out this week now that I know what path to follow. Thank you again.
since the relay clicks I'm hoping it is just the fan motor or the wiring between the two.
thisdamnhonda
21
Feb 26, 2012 09:47 AM
dudeomega2000
Jan 6, 2008 09:51 PM
Nameless Warrior
Dec 15, 2006 01:24 PM
