A/c blows cool but not cold.
Old Sep 30, 2018 | 09:52 PM
Lvmanforsale's Avatar
Default A/c blows cool but not cold.
Hello every one I have a 1995 honda accord ex. I have replaced the ac compresser, dryer, condenser, evap under that dash with a new expansion valve. The compressed kicks on after I put freeon in the system. I put 23oz as for what it calls for. I dont understand what I have missed. If anyone can help that would be great. NOTE.. At night time the ac works great but when it's hot like it been here 98. It just lightly blows cool.
Old Oct 1, 2018 | 01:51 AM
bw77's Avatar
Default Re: A/c blows cool but not cold.
Are the fans working?
Old Oct 1, 2018 | 05:44 AM
yes fans are working
Old Oct 1, 2018 | 05:47 AM
bw77's Avatar
Maybe you have a leak. Get a set of gauges and
check the low and high pressure sides.
Old Oct 1, 2018 | 05:55 AM
That's funny that you say that because last night I drained everything just to check to see if I had a leak and I do not have a leak I had it holding for over an hour and a half and it did not leak at all
Old Oct 1, 2018 | 06:44 AM
bw77's Avatar
https://honda-tech.com/forums/honda-...ioner-3321218/
Read post #4, look at the pressure chart. It's for a 98-02 Accord.
I think you need the pressures and temps to troubleshoot.
The new parts you installed may not be working correctly.
Old Oct 1, 2018 | 07:17 AM
Like I said I have charged everything correctly is there anything that I may have missed?? A sencer a plug?
Old Oct 22, 2018 | 04:52 PM
schreps's Avatar
did you install a OEM or after market expansion valve? correct amount of oil in the compressor and condenser? clutch slipping? belt slipping? did you have UV dye in the system? put an AC thermometer in the center vent and measure temp with fan on low, vent set to recirculation. Do you get near 40F at night or any ambient condition?
Old Oct 22, 2018 | 04:53 PM
Well because I wasn't getting any help from anyone I just decided to replace everything switches and a couple of the lines and now it's working
Old Oct 22, 2018 | 04:54 PM
Northernlightz's Avatar
Check the wiring.
Hondafreak559
Aug 3, 2016 04:43 PM
carstudent
Jan 2, 2014 11:42 AM
bill_stnly
May 17, 2010 12:03 AM
talontedtsi1995
Aug 19, 2009 05:24 PM
karrar55
Aug 10, 2009 03:44 AM
