Rear bumper vents?
Old Sep 30, 2018 | 04:20 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Rear bumper vents?
just wondering what type of results everybody gets from added rear bumper vents? Also at what speeds do these vents actually become a helping factor? I see most true race cars using vents, but I have no clue what point they are needed. I’m guessing if your car is trapping over 120mph these vents become helpful? I would like to know if anybody had a before and after speed difference results? I just have not been able to find much information on this.
thanks
Old Oct 28, 2018 | 06:05 AM
sneakysneaky's Avatar
Default Re: Rear bumper vents?
If you are running 165 mph in the half mile you can expect to pick up 2 mph in the half mile from dropping the rear bumper on an hatch. That’s what I’ve seen at wanna go fast, but he dropped the bumper bar as well. So maybe .75-1 mph in the quarter. Dropping the weight may have been as much to blame for it though.
Old Oct 28, 2018 | 06:12 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
for such a small gain, why has it been such a must for every drag car? Placebo effect ?
Old Nov 7, 2018 | 05:53 AM
FlewByU352's Avatar
Years ago a friend of mine and I finally lined up. We made almost identical power and had the same chassis, once he cut out for bumper holes he picked up 2MPH in the 1/4 and would inch me out on the big end every single time! We would literally be door to door until 4th gear and he would start pulling ahead slowly and prior to the holes it was dead even running identical MPH and times. It certainly made me a believer because this wasn't even on high HP cars, I'm talking cars trapping low 100's he picked up 2MPH. I'm sure on cars trapping over 120MPH the difference is more than 2MPH based on what I had personally experienced.
Old Nov 7, 2018 | 09:24 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
thats good info, only a few mph don’t sound like a lot, but in racing inches are everything
thanks
Old Nov 7, 2018 | 07:30 PM
motoxxxman's Avatar
just so some people can learn some things; a rear splitter with flat bottom would have an equal effect. It's all about aerodynamics. If you look under your car, the rear bumper actually works like a small parachute at higher speeds. Cut holes in the "parachute", or add a flat plate so the air totally bypasses the "parachute", and you've drastically reduced the wind drag. Obviously adding a plate adds weight and cutting holes reduces weight. So the choice is pretty obvious.
Ever stick your hand out the window at 120mph and cup the air? It's a considerable amount of drag. Now imagine the surface are of your hand compared to an entire rear bumper. Well, half the bumper...
Old Nov 9, 2018 | 07:24 AM
All of the large manufacturers build in plastic or carbon fiber belly pans in any performance car that’s built today. I would think that would be the way to go over trying to equalize pressures. But same car pulling the bumper off to gain 2mph in the 1/2 mile says a lot. You can look up wanna go fast OCALA on YouTube for last year if you want to see for yourself.
Old Nov 9, 2018 | 07:38 AM
seelback's Avatar
look up the cars that run at World Cup Finals and check out their rear setups. That will let u know whats good. I saw some pretty crazy rear diffuser designs this year.
Old Nov 11, 2018 | 06:26 AM
DumpdEJ6's Avatar
I like the tuna here
You can make your own rear diffuser out of ABS, this is how mine turned out:
Old Nov 11, 2018 | 03:38 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Great concept, but I’ve seen soooo many parts fly off cars over 100mph that I’d rather just cut than take the risk
Old Nov 12, 2018 | 05:27 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
That turned out super nice dumpedej6! Normally I'm not a big fan of diffusers especially since most the cars in the northwest I see them on are appearance built cars and don't generally have anything related to actual preformance besides the cosmetic stuff. That does look clean and definitely took your time to make a quality piece out of it
Old Nov 13, 2018 | 06:48 AM
DumpdEJ6's Avatar
Thank you! I definitely attempted to make mine functional, from the research I've done, a rear diffuser angle of around 7-10 degrees is optimal. I still need to do work on a full length flat undertray to really increase its functionality.
cybersec
Jul 6, 2017 06:22 AM
H-T guy
May 9, 2007 07:25 AM
3rdGteg
Nov 2, 2003 08:11 AM
StreetRacnGsR
May 28, 2003 03:19 PM
wm5holla
Mar 29, 2003 09:48 PM
