Transmission & Drivetrain Gearboxes, Differentials, Clutches
input shaft bearing noise after changing tranny fluid
Old Sep 29, 2018 | 09:10 PM
depo's Avatar
Icon5 input shaft bearing noise after changing tranny fluid
I'm puzzled, I changed the transmission fluid in my low mile S2k and after doing so I got input shaft bearing noise - it appears only when the clutch is engaged and disappears when the clutch is depressed. I only notice it in neutral, it's not loud enough to be noticed in this car when driving. ]
I used redline 75W80 GL-4 GEAR OIL as they recommend. Can it be the fluid? I've used redline before in other cars with great results. Not sure if I should swap to Honda MTF or try the recommended Motul, which is a touch thicker. I'm not sure what was in it before, I just know it wasn't the factory fill.
What's the best approach?
Old Oct 8, 2018 | 02:14 PM
Aquafina's Avatar
Default Re: input shaft bearing noise after changing tranny fluid
Changing to a different fluid won't fix a bad bearing. The bearing needs to be replaced.
I avoid Redline.
hillbillycivic
Dec 4, 2013 07:54 PM
Rooftop voter
Nov 3, 2010 06:11 PM
Xxcivic97xX
Aug 22, 2010 07:22 PM
AznInvasion
Sep 5, 2007 11:54 AM
JDM SLICK
Feb 16, 2005 05:38 PM
