95 lx accord crank no start
Old Sep 27, 2018 | 10:27 AM
johnCurtiss17's Avatar
Default 95 lx accord crank no start
I've been fighting this car for a few days now have checked spark at each cylinder it has fuel and no codes. Will just crank nothing else. Thanks!
Old Sep 27, 2018 | 03:58 PM
brakedrum's Avatar
Default Re: 95 lx accord crank no start
Was it starting properly before this trouble?
Old Sep 27, 2018 | 10:29 PM
GhostAccord's Avatar
There is always something a miss when a member reports that their engine has both spark and fuel but won't start.
How bright is the spark? is it bright at all cylinders
How did you confirm fuel inside every cylinder? Did you verify that each injector was firing, Do you know how much pressure is in the line?
What were the circumstances leading up to the no start issue? Was it taking a while to start previously or running rough. Or did you just wake up one morning and it quit working? Do you know when the last tune-up was performed, timing belt, spark plugs, wires, cap, rotor, valve adjustment etc..etc...?
redmon_e
Jan 5, 2015 11:47 AM
russian239
Sep 19, 2014 07:19 AM
akacoke
Jan 19, 2011 09:47 PM
vinuneuro
Oct 9, 2006 10:36 AM
