6th Gen Accord Turbo?
Old Sep 26, 2018 | 07:44 PM
diulay_pkjai's Avatar
Default 6th Gen Accord Turbo?
I'm looking into turbo for my 6th gen Accord. It seems like all the kits left on the market are the eBay kits. I know those are incomplete kits. I'm expecting the turbo will need to be replaced with a brand name turbo, but are the other parts on those kits ok? Seems like I'll need to get injectors and fuel management separately. I'm looking at Evo 510cc injectors, would those fit? Do I need resistor box for those? Anyone used one on their Accord/Prelude? Thanks.
Old Sep 26, 2018 | 08:26 PM
Aradin's Avatar
Premium Member
Default Re: 6th Gen Accord Turbo?
Turbo will be fine as long as you run an oil restrictor and install it properly. Piping, intercooler, blow off valve and wastegate will all be fine to use as well. Yes you will need to get your fuel system separately. Injectors, fuel pump and management via ECU hardware/software like Neptune/Hondata. Evo/DSM injectors work fine. I have installed many, many sets over the years and yes they need a resistor box.
Old Sep 26, 2018 | 10:44 PM
Thanks for the helpful reply.
Old Sep 27, 2018 | 03:16 AM
shipo's Avatar
Is it safe to assume you have a 4-cylinder Accord with a manual transmission? If you have a V6 version or an I4 with an automatic transmission, don't bother with the turbo.
Polakatl
Nov 27, 2004 08:28 PM
KamakazieX
Aug 7, 2004 05:02 AM
