Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cam & Crank Shaft Sensor Repleaced but not fixed
Old Sep 23, 2018 | 11:19 AM
Dickie25's Avatar
Default Cam & Crank Shaft Sensor Repleaced but not fixed
I replaced the Cam and Crank Shaft Sensors twice now and the car is still losing power at about 2500-3000 RPM. right be fore you shift really. check engine light is still on, I checked the connections and they are good. Any ideas would be helpful. Thanks!
Old Sep 24, 2018 | 06:06 AM
NDNV's Avatar
Default Re: Cam & Crank Shaft Sensor Repleaced but not fixed
Did you use OEM Honda sensors? Makes a difference.
Old Sep 25, 2018 | 12:39 PM
thisguyaves's Avatar
check engine lights? Sounds like limp mode at vtec engagement.
Old Sep 26, 2018 | 08:42 AM
NDNV's Avatar
What is the code? Both sensors failing at the same time sounds like a very rare occurrence.
Old Sep 27, 2018 | 02:00 PM
might have slipped timing, that would give the same code as well
Harissummo
May 24, 2017 02:22 AM
heinrichranches
K Series
Aug 7, 2013 03:30 AM
MinMet
May 31, 2012 05:41 PM
