left rear turn signal not working
Old Sep 20, 2018 | 10:53 AM
eddie7978's Avatar
Default left rear turn signal not working
2000 civic hatchback
how can i diagnose my left rear signal light not working
i put in the working bulb from the other side and it’s not working..
it just clicks fast..
Old Sep 21, 2018 | 04:06 AM
mk378's Avatar
Default Re: left rear turn signal not working
Corroded socket, broken wires where they go from the hatch to the main part of the car (if the light in question is on the hatch door).
Clicking fast is an intentional feature to tell you that one of the bulbs is not working.
Old Sep 21, 2018 | 05:08 AM
eddie7978's Avatar
yea the left rear doesn’t work even when i put a good bulb in
Old Sep 21, 2018 | 07:15 AM
eddie7978's Avatar
do u know where the grounds are for the l/r turn signal??
Old Sep 21, 2018 | 11:53 AM
NVturbo's Avatar
O.G. triple O.G.
bad turn signal switch??
Old Sep 21, 2018 | 04:22 PM
eddie7978's Avatar
so if anyone’s wondering the issue is the wire not touching the socket thanks
Old Sep 21, 2018 | 10:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That is the wrong socket for the turn signal bulb... the proper socket would have a single raised button right in the middle of the base to make contact with the bulb. I suppose you could use a dual filament bulb in the socket you have and it should work...
sachit
Lighting
Nov 1, 2018 07:26 AM
lharper
Mar 22, 2017 10:40 AM
superfly23
Honda CR-V & Element
Feb 22, 2016 01:00 PM
Acethriller
Lighting
Jan 4, 2014 07:58 PM
agentx
Jan 14, 2009 10:04 PM
