f22a1 vs f22a6
i have a 92 accord and i just aquired the f22a6 i intend on doing the swap but want to know a few things first like for instance . to my knowledge the f22a series all the parts are genuinely are univirsal minus the ecu and extra oil cooler but the intake mainifold will it work i understand that it may not be recomended but as im broke will it cause to much damage
F22A1: 125 hp (93.21 4 kW) at 5,200 rpm. (Accord DX, LX). The 1992–1996 Prelude S also had a F22A1 but because of a different, more aggressively tuned ECU (P12) the power output is 135 hp (100 kW).
F22A6: 140 hp (104.40 kW) at 5,600 rpm. The F22A6 is the same as the F22A1 except for a slightly more aggressive camshaft, a better flowing cast exhaust manifold, a different more aggressively tuned ECU (PT6), and a different intake manifold that utilizes IAB's and also has a bigger plenum. The F22A6 also has a windage tray in the oil pan, and stiffer valve springs to accommodate the more aggressive camshaft. In cars with an automatic transmission there is an oil cooler present on the back of the block as well.
