Doesn’t want to start just every now and then..?
Old Sep 18, 2018 | 05:32 PM
popthatclutch13's Avatar
Default Doesn’t want to start just every now and then..?
My car is a 1991 Honda CRX. It starts up like a normal car 95% of the time.. but it randomly doesn’t want to start just once every blue moon. It’ll just crank and crank and crank.. then i’ll come back out a little bit later and it’ll start right up like nothing happened. I have replaced the distributor, and have cleaned the carbon build up from the ignition switch.. could this be a bad main fuel relay? That’s just my last guess. Can’t seem to think of anything else. Just wanted to see what you all think before i buy a new relay.
Old Sep 19, 2018 | 04:11 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Doesn’t want to start just every now and then..?
Sounds like a main relay issue - especially if it doesn't crank well when hot. I've also had issues with the ignition switch - never tried cleaning it like you say you did...I just replaced it with a new one.
Old Sep 19, 2018 | 05:59 PM
so is the “main relay” and the “main fuel relay” the same thing?
Old Sep 19, 2018 | 09:29 PM
arries289's Avatar
Take the main relay out and look at the solder joints with a magnifying glass. If you see cracks in the solder, that is likely the culprit. They can be resoldered but a new one is cheap.
Old Sep 20, 2018 | 03:12 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yes. The main relay controls the fuel pump and other components as well.
vladiscoolej1
15
Oct 23, 2010 06:55 PM
rb_888
Jun 17, 2008 03:51 PM
blaxican05
Feb 23, 2008 08:47 PM
therealciviczc
May 15, 2002 12:08 PM
