Hey everyone i am new to this site and in major need of help I have a 2wd 91 civic wagon dx had the d15b2 in it that recently blew up I swapped a d16z6 into it from a 94 eg civic did the dpfi to mpfi swap and obd0 to obd1 swap with the rywire conversion harness I wired the injectors straight to the ecu into "a1, a3, a5, a7, and all injector grounds to a15" is that correct? Car Will turn over but will not start I double checked all plugs and connectors everything is connected checked all wiring its all solid what could i be doing wrong its so close to being done and was hoping to drive it before winter hits and i have to park it can someone give me a detailed step by step dpfi to mpfi instructions without using the resistor box and having the rywire conversion harness for obd0 to obd1 is there extra wiring I have to do if i have the rywire harness any help with what i did wrong is greatly appreciated
