Blown head gasket?
Old Sep 12, 2018 | 05:36 PM
Elijah Trevino's Avatar
Default Blown head gasket?
When I turn my car on no smoke comes out but when I go from first to second gear it smokes a bit then stops would that be a blown head gasket ?
Old Sep 12, 2018 | 06:54 PM
avisitor's Avatar
Default Re: Blown head gasket?
A badly blown head gasket would leak ... coolant into cylinders, gas out during compression stroke
Not so bad, there might be rough idle, exhaust gas in the coolant, might see some creamy stuff in the radiator
Hard to say if it is or isn't. It can be tested by a kit that checks for exhaust gases in the radiator
Old Sep 12, 2018 | 08:18 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
what color smoke? Mine will smoke some depending on the load I have on it, but its tuned very rich and it blows almost a black cloud. A blown head gasket will usually not stop smoking, it’s usually going to be a steam that smells sweet from the burning antifreeze
Old Sep 12, 2018 | 08:47 PM
It throws out white smoke when I push the gas from frist to second gear but then it'll stop and the smoke isn't constant. So idk if the gasket isn't completely blown or if it is just a small leak
Old Sep 13, 2018 | 03:50 AM
mk378's Avatar
It sounds like you are seeing oil smoke from worn rings. This kind of smoke gets worse when you floor it and continues until you let off the gas.
The first symptom of a leaky head gasket is losing coolant from the radiator, leading to overheating. Only in a severe case will you see water "smoke" from the tailpipe. This "smoke" is of course actually steam and it will smell like antifreeze.
Old Sep 13, 2018 | 02:14 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
is this car turbocharged? I’ve seen turbo seals have some blow by also
efjones9
May 1, 2009 06:48 PM
gsrvtec2
Oct 16, 2005 12:14 AM
MantisX
Aug 21, 2005 07:15 PM
00ITR #543
Aug 23, 2002 05:47 AM
wessieball
Apr 22, 2002 12:51 PM
