2002 Honda Accord EX 6 Cyl . Burning Smell & Leaking Power Steering Fluid
Old Sep 10, 2018 | 02:09 PM
relunner4th's Avatar
Default 2002 Honda Accord EX 6 Cyl . Burning Smell & Leaking Power Steering Fluid
i've been smelling a burning smell with my car recently. i have to replace my power steering fluid (using ATF instead) every few days due to leaking somewhere.
Could this be the cause of the smell? what is the best way to determine if it's the pump or a hose making the smell, or if it's even that causing the smell?
any help or guidance to a youtube video to assist would be appreciated.
Old Sep 10, 2018 | 03:11 PM
shipo's Avatar
Default Re: 2002 Honda Accord EX 6 Cyl . Burning Smell & Leaking Power Steering Fluid
Spray ATF on a hot exhaust pipe and you'll get the smell you're smelling. Fix your power steering system and you should be good to go.
Old Sep 11, 2018 | 08:13 AM
Kevs02Accord's Avatar
check the hoses for leaks, then look over the pump itself.
Old Sep 11, 2018 | 08:18 AM
it appears to be on the exhaust towards the back of the engine, closest to the windshield, so when i pop the hood, i can see the smoke (not fire smoke, appears to be exhaust burn smoke) it comes up between the engine and the windshield, would that still possibly be the power steering hose?
TPhilips
Oct 10, 2017 09:35 AM
dujac
Apr 22, 2014 04:04 PM
BigTwigs1981
Sep 4, 2011 11:27 PM
