F23A Swap into 94 ACCORD MANUAL Help
I've tried looking around a bit but couldn't really find anything.
Had a blown F22B2, bought an F23A to swap. I have the Engine bolted to Tranny ready for mounts.
It's an F23A Engine (Previously from an automatic, I don't know whether this matters or not)
With a P2A5 Manual Trans from the F22b2. I don't know what mounts will fit. 94 Accord LX Manual Transmission mount do not fit. 98-02 Manual Tranmission mount do not fit either.
I figured the tranmission mount would remain the same and the engine mount would be different since I changed the engine not the tranny.
Help, where do I find mounts that fit?
H day is around the corner.
Was your car already 5-speed? Or are you converting that as well? I ask because if the car was already manual trans, you would just reuse the stock trans and mount. You're kind of vague what your car already has and if you are converting to 5-speed as well.
I think I found the issue. I looked around and found a diagram for my model car, there seems to be a bracket that connects the transmission mount to the transmission. After looking around some more, I found out that part is discontinued and hard to find. Purchased an Innovative Replacement Mount for the transmission, seems to replace the mount and bracket with a one piece mount design. Ran me 172$ with S&H, have not recieved it in the mail yet. Will keep you updated. The car was originally a 5 speed and will be kept a 5 speed, original transmission.
preludeboybmw
Nov 22, 2007 09:47 PM
redsikiller
22
May 15, 2006 01:46 PM
jazz215
Jul 16, 2003 11:28 PM
