Rough Idle/Common Misfires
Old Sep 4, 2018 | 08:10 AM
Kevin Wood's Avatar
Default Rough Idle/Common Misfires
Hello, i currently have a 1988 honda accord and its got a few issues. With only 170k miles its a pretty decent car. Only issue is, it has a very common misfire. The car runs as needed but is very noticeably heard, and with the smell of gas. There is no blow-by ive already checked that. I have Checked plugs, and they all are fine. Just to be 100% sure i changed them out along with the wires from the distributor. Yet, the problem proceeds. Im not sure where to go from here other than the ignition coils or taking a look inside the distributor. Any recommendations?
Old Sep 4, 2018 | 08:29 AM
ftcc's Avatar
Default Re: Rough Idle/Common Misfires
valve adjustment maybe.
check vacuum leak maybe
that idle screw maybe
clean throttle body
clean mas maybe
clean erg passageway maybe
ar you running rich or lean?
shanec80
Mar 19, 2018 04:07 AM
buzlink
10
Aug 28, 2009 11:00 AM
SRZsmack
12
May 25, 2009 09:27 PM
madcrossover
Feb 19, 2005 09:13 AM
Accord88
Feb 23, 2003 05:53 AM
