All items are used unless noted. Can send additional pics upon request. Buyer pays shipping and fees.
* New Edelbrock/Russell 670530 Blue Anodized Aluminum -6AN Flare to 16mm Metric Adapter Fitting. Asking $10
* New Aftermarket Clutch Slave Cylinder. Asking $15
* New Bando 4040252 / 4PK635 Serpentine 4-rib belt. Asking $5
* New OEM Intake Tube Arm Spring (17244-P72-000). Fits ITR and other models. Asking $5
* New? OEM BVTEC Timing Belt 14400-P72-014. Asking $20
* NPW (Japan) B-Series Water Pump. In good condition with no play in bearings. Asking $20
* OEM 2001 Acura Integra Type-R motorized antenna. Good working condition. Asking $85
* OEM 2001 Acura Integra Type-R intake manifold bracket. Asking $15
* OEM GS-R Oil Separator / Black Box with pcv valve, joint valve and o-ring. Asking $30
* OEM 94-01 Integra dash switch delete. Very good condition. Asking $5
* OEM 94-01 Integra Radiator Fans w/ pigtails (no plugs). Excellent working condition, normal wear. Asking $20 each or $30 for the pair
* OEM UKDM ITR carbon faux driver-side vent (RHD). Very good condition, no scratches. Asking $20
* OEM Honda Denso radiator cap. Good condition. Asking $10
* OEM Honda oil cap (from B-series). Good condition. Asking $10
* OEM Honda/Denso OBD2 Alternator. Good working condition. Asking $30
* Jackson Racing 5.95" Lightweight Crank Pulley (from GS-R High Boost kit). Rare piece in good shape. Asking $130
* New OEM Optional ITR Red Billet Spark Plug CoverSOLD * New OEM Optional ITR Red Battery Tie DownSOLD * OEM 2001 Acura Integra Type-R Engine Harness. Complete working conditionSOLD * OEM 2001 Acura Integra Type-R gunmetal "A" wheel cap (single)SOLD
* OEM 98-01 Integra 3-Door Rear Mud Guards. Great condition. Comes with self tapping screwsSOLD * OEM 94-01 Integra GS-R 4-Door catback exhaust. No cat.SOLD * OEM GS-R Throttle Cable. Very good conditionSOLD * OEM GS-R Cams + Gears. Very good conditionSOLD * 70mm Throttle Body with coolant delete. Comes with TPS and throttle cable bracketSOLD * DC Header bottom piece only from a 4-2-1 setup for B-SeriesSOLD * UEGO AFR (AEM 30-4110) Combo. Used for about a year (car was mostly garaged). O2 Sensor has about 500 miles on them SOLD * AEM Boost Gauge (AEM 30-4406 30-35 psi) Perfect working order. Comes with everything including AEM stickers, black and white face plates, silver bezels optionsSOLD
Reason: sold item
