Which size tires should I got with?
Old Sep 3, 2018 | 02:39 PM
90 CRX SI's Avatar
Default Which size tires should I go with?
90 CRX Si with 15” si wheel wheels I’m getting new tires so I was wonder which is better 195/55/15 or 205/50/15 ? I’d like your guys opinion thank you
Old Sep 3, 2018 | 03:38 PM
2x0's Avatar
2x0
10 Year Member
Default Re: Which size tires should I got with?
Kinda depends on what you’re using it for, but there will be almost no noticeable difference between those two sizes.
Old Sep 3, 2018 | 03:54 PM
90 CRX SI's Avatar
I like how the 205's are a tad bit wider. I bought a set of si wheels yesterday and (2) had 195/55/15 and (1)185/65/15 (1)205/50/15
Old Sep 3, 2018 | 03:56 PM
2x0's Avatar
2x0
10 Year Member
Then go with the 205’s.
If you’re concerned with traction, the treadwear rating and type of tire will make all the difference, not 10mm of section width.
Old Sep 3, 2018 | 05:39 PM
acmoc's Avatar
both of those tires are wrong
the 55's are too tall. Unless you want a really tall sidewall. It will throwoff your speedo and slow down your acceleration.
The 205/50 is still too tall. On a x7" rim, the width won't make a difference. It will balloon over the rim and have a soft sidewall. The speedo will be off and your accelleration will suffer.
The 185/65 is still too tall, just narrower, and will suffer the same as the others.
You want 195/50/15
Old Sep 4, 2018 | 11:38 AM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
I agree 195/50-15
da'ee
Mar 25, 2008 10:52 AM
4drITR
Apr 20, 2006 08:56 PM
90Zcrx
Jun 21, 2004 08:03 AM
808State
Oct 19, 2003 04:42 PM
JSJ EG6
18
Sep 27, 2002 06:09 AM
