clutch pedal adjustment insufficent
bought 02 accord, after awhile, clutch pedal - "push rod->master cyl" disconnected!
(assumed set screw not tightened enough.)
Removed master cyl to put end on push rod again, reinstalled, bled system,
-> then had to adjust push rod to very limit
and it still wasn't disengaging clutch cleanly fully depressed...
Is this simply a matter of clutch master (or slave) needing to be replaced?
(or rather clutch problem?)
(didn't notice any leaking at either cyl, reservoir remained constant before / after)
