question about CKP,CYP,TDC sensors
Old Aug 27, 2018 | 01:14 AM
hondamyheart's Avatar
Default question about CKP,CYP,TDC sensors
hi
what does CKP,CYP,TDC P side / CKP,CYP,TDC M side means?
I am making a custom race harness for my 2000 civic h22 with OBD1 P28 ecu and i want to make sure my wiring is correct. The dizzy has the OBD2A connector.
CYP-P ||Pin 4 Wire Color Orange|| goes to B11
CYP-M ||Pin 6 Wire Color White|| goes to B12
TDC-P ||Pin 3 Wire Color Orange/Blue|| goes to B13
TDC-M ||Pin 7 Wire Color White/Blue|| goes to B14
CKP-P ||Pin 2 Wire Color Blue/Green|| goes to B15
CKP-M ||Pin 5 Wire Color Blue/Yellow|| goes to B16
Old Aug 27, 2018 | 08:40 AM
Feriohhh's Avatar
5 Year Member
Default Re: question about CKP,CYP,TDC sensors
Per the service manual (96-200 civic)
P is for detection.
M is the ground.
Old Aug 27, 2018 | 09:25 AM
P is for detection.
M is the ground.
thanks bro. That confirms my wiring is correct.
Old Jan 21, 2020 | 05:08 AM
Rafael Astro's Avatar
[QUOTE=hondamyheart;51715824]hi
what about pin number 1?ignition input signal
Old Jan 21, 2020 | 07:42 PM
muellersfan's Avatar
The ECU uses this Yel/Grn wire to send a ground pulse to the ICM, thereby causing the coil to generate high voltage spark at the spark plug.
flyinryanbro
Nov 7, 2009 09:19 PM
HarosGSRek
May 21, 2009 12:36 PM
99delsol
Sep 13, 2006 09:09 PM
skimb37
Nov 28, 2003 09:56 AM
DsMWookie
Mar 9, 2003 07:00 PM
