1996 honda accord f22b1 swap help
Old Aug 25, 2018 | 05:47 PM
James Kennamer's Avatar
Default 1996 honda accord f22b1 swap help
I bought a 96 honda accord with a f22b1 swap out of a 95. It won't run. Thinking it has the wrong way. If the ecu is from an automatic will the car not run? Any help is greatly appreciated. Thanks so much guys.
Old Aug 26, 2018 | 04:24 AM
hondaslave1342's Avatar
Default Re: 1996 honda accord f22b1 swap help
More info...how is the distrubor wired...any engine light...lack of spark.fuel..compression...goggle search is your friend..more info....is it cranking...
Old Aug 28, 2018 | 05:08 AM
Fitz Williams's Avatar
10 Year Member
The 94-95 EX uses a unique distributor with a two plug wiring harness. If you have the 96 harness, make sure you have a 96 distributor.
Katman
Jan 3, 2017 10:04 AM
Crxh22ajdm
Dec 19, 2012 02:22 PM
