2000 Honda Civic 4D sedan, AT, oil leak
Old Aug 22, 2018 | 08:50 AM
srose111's Avatar
Default 2000 Honda Civic 4D sedan, AT, oil leak
better view
This is on a 2000 honda civic LX 4 door Sedan Auto Trans.
When you follow the oil pan from L to R the engine meets the tranny...see arrows for where oil is leaking.
Question for forum.
1. What is this part or seal or 2 components called?
2 Is it likely leaking from here or above and dripping down? ( I cannot see)
3. If i discovered the oil filter just a tad loose with hand tightening, could the oil be leaking from there and flowing down to this point?
thank you
See arrows for where I believe it is leaking??? What part is on the L of bolt and is that the transmission on R? What is this seal called?
Old Aug 22, 2018 | 10:18 AM
hondamark35's Avatar
Default Re: 2000 Honda Civic 4D sedan, AT, oil leak
this is where oil gathers when the filter comes off (or isn't on all the way...)
the part with the arrow is just a brace (block/trans "stiffener")
probably also have an oil pan gasket leak (worthwhile to replace), a rear main seal leak (not usually worth the effort unless you really like taking your car apart on the weekends...), and likely more from higher up dripping down (distributor o-ring which is cheap and easy and failure-prone and the valve cover gasket which is easy to replace).
Old Aug 22, 2018 | 10:26 AM
srose111's Avatar
Awesome thanks for the info.
I re-hand tightened the oil filter.... I was a bit loose. Will check leak again in a few hours.
Will def consider oil pan gasket. Thx!
There is no pooling of oil where distributor is, so I ruled that out.
Old Aug 22, 2018 | 11:17 AM
tony_2018's Avatar
Fish Twig
clean up oil with brake cleaner, refill oil, check for leaks again.
Old Aug 22, 2018 | 03:59 PM
mk378's Avatar
+1. Oil found on the bottom of the engine has usually run down from somewhere else.
If there were a leak of the shaft seals of either the engine or the transmission, the oil (or transmission fluid) will usually come out of the square hole you see in the bottom of the case.
Old Aug 24, 2018 | 05:30 AM
srose111's Avatar
Thanks MK, I know exactly where you are talking about with the square box. ...nothing there. I think it was a dumb case of me not tightening the oil filter enough and it ran down. Im going to degrease all that S#$$# and see if it comes back, as of now the leak has subsided. Thanks again
2018HBowner
Honda Civic (2016 - Current)
12
Jul 24, 2019 04:01 AM
boyong07
Feb 24, 2008 07:47 PM
kekekekevin
23
Jul 22, 2006 04:38 AM
MugenPoweredLude
Jan 28, 2003 02:04 PM
