Im looking for new wheels. I'm going to daily the car and evenventualy turbo it as a weekend car. Not a track car. I was looking into aodhan ah01. Would I need to roll my fender or cut anything to fit 16x8 at about + 30 or 35 on 205.50.16? Car is on stock suspension but I want to drop it 2 inches at the most. 8 width sound like a lot but that's why I'm here. Any suggestions will be apreciated
Im running 16x7 +30 and wont rub at all, with 10mm spacers it touches the rear wheel well badly, so I assume with 16x8 +30 it will need to be rolled a lil bit
I have a 1993 LS lowered 2+ inches with avid1 15x8 et25. Wheels ( pictures below ) I’m running 185-55-15s and I have some room for fatter tires. I think the key to achieving no rubbing will depend on the offset of the tire. With more offset, you’ll be able to get away with more rubber. Less offset and you’ll need to get a narrower tracked tire and stretch it so that there’s enough clearance when the springs compress. Keeping you camber angle negative will also help with clearance... to sum it up, the integra should be forgiving with an 8 inch wheel, rolling fenders should be your last option for fitting.
