D/B series Fuel pump
Old Aug 20, 2018 | 07:23 PM
Randomnoob's Avatar
Default D/B series Fuel pump
so I recently did a Jdm 00 B20B swap into my 99 ex , After a day my fuel pump wasn’t priming anymore. My stock Fuel pump on the ex was already having problems so im guessing it just went bad. What Fuel pump should I run with my Stock B20 ? Only bolts on I have is a Aem Fuel rail and short ram intake
Old Aug 20, 2018 | 07:34 PM
egsleepercivic's Avatar
Default Re: D/B series Fuel pump
here you go
Amazon Amazon
Old Aug 21, 2018 | 09:40 AM
barrywayne's Avatar
Originally Posted by egsleepercivic
If you have to change the pump, spend the extra $20-$30 and get a 255walbro so if you do anything in the future you’re not having to pull the pump again and Spend another $100.
Old Aug 21, 2018 | 12:44 PM
255 is too much for a stock motor and fuel pressure regulator in my experience. It can cause you to run rich.
Old Aug 21, 2018 | 04:22 PM
barrywayne's Avatar
dude you’re so full of ****.. cut it out.
Old Aug 21, 2018 | 10:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I think egsleepercivic means with a stock ECU... however, if you have a tuning solution, the elevated fuel pressure can be compensated for.
Old Aug 22, 2018 | 04:19 AM
barrywayne's Avatar
simple $40 blox fuel pressure regulator would fix that. But yes tweaking the tune will do it too
Old Aug 22, 2018 | 06:32 PM
For my B20b in my integra, I wanted a little upgrade so looking at the info in the following thread
https://honda-tech.com/forums/acura-...-info-3166803/
I went with the Denso 110 lph
Amazon Amazon
Works fine no issues, I plan on using the same pump in my 93 si with B16a
good luck
EJ8CIVIC
Jul 5, 2015 12:07 PM
crazyguy
Aug 2, 2007 10:09 AM
erubio14
Nov 25, 2005 10:28 AM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
