Changing stereo ground to reduce interference from cig-lighter charger?
Old Aug 17, 2018 | 09:28 PM
TheIVJac|{al's Avatar
Icon5 Changing stereo ground to reduce interference from cig-lighter charger?
Every time I charge something through the cigarette lighter I get crackling through my stereo. I'm planning on installing a dash-cam soon but I really don't want to have to deal with the interference when I listen to FM. I remember reading somewhere about the ground for the stereo being the problem, has anyone tried changing this? Were you successful? If you have a How-To, that would be great! I looked at the manual, found the ground directly behind the stereo, but the 10mm nut is facing away and is a bit hard to get to, not sure it's worth the effort?
Thanks for any help
Old Aug 19, 2018 | 01:18 PM
Default Re: Changing stereo ground to reduce interference from cig-lighter charger?
Bump.
From what I read on other forums for other cars, sometimes it's just the quality of the charger that causes that to happen. My concern is if that's not the case with mine and when I install a dash-cam, if it's still going to happen.
Do you have a dashcam? Do you experience any of the static/loss of signal strength on FM stereo?
Old Aug 21, 2018 | 09:53 AM
thewrai6th's Avatar
Originally Posted by TheIVJac|{al
Bump.
Depends on the noise. Many times its the + line that is noisy, you'll hear a high pitch whine with the RPM. They sell in-line noise filters for this. For the ground, I usually use a bolt in the chassis/firewall somewhere.
Old Aug 22, 2018 | 04:52 PM
Thanks for that, I don't hear an rpm whine so I'm fairly certain it must just be the ground then.
SickSi99
Aug 11, 2016 07:30 AM
CRXguy_88
18
Sep 2, 2011 08:39 PM
m R g S r
Audio / Security / Video
Dec 16, 2004 05:42 PM
Nothing.Special
Jul 13, 2004 07:33 PM
Import Horizon.com
Jul 23, 2001 05:55 PM
