Need help with exhaust 97 Integra GSR!
Looking to purchase a new exhaust and header for my 97 Acura Integra. I need an exhaust complete with cat converter. Anyone know of any good exhausts that comes with a cat converter with a deep sound?
I need opinions and links!!
Most of the exhausts im finding online don’t come with a catalytic converter so I’m getting a bit confused. Please give me some insight peeps
No I live in PA, I’m deciding on if I should by stock exhaust with a cat converter or a racing exhaust that I can just remove the cat after the inspection. The one I have on now doesn’t have a cat converter and it’s welded where the converter should be so yea lol
I just need to know some good deep sounding exhausts that come with the full package or if I need to buy them separately and take the loss in a good deal...
Some states have a pretty loose inspection where they just want to make sure there are no check engine lights an everything is in order. Some might want you to pass a sniffer test and some will want all orginal/ CARB approved parts etc....
Exhausts don't typically come with cats. They're usually called "cat back" exhaust systems because they replace everything behind/after the cat. You utilize your stock cat or test pipe or whatever. So, you will need to figure out the cat situation yourself. You can buy a magnaflow replacement cat and have an exhaust shop weld it up to your system, then pair it with any off the shelf exhaust you end up going with.
I don’t know what exhaust I have on my car currently but I do know that it’s welded where the cat is supposed to be. So either I’m going to have to buy an exhaust with a bolted cat that I’m going to have to buy speerarely or try to find a complete exhaust setup with a cat already on it (even if it’s a stock exhaust). What do you all think I should do? I need a cat just to pass inspection.
