2000 Civic Low idle and no rpm...Help a man please!!!
Old Aug 11, 2018 | 08:03 PM
Pat_Ek1984's Avatar
Default 2000 Civic Low idle and no rpm...Help a man please!!!
Thanks for stopping by to read my cries of sorrow...
​​​​Its a 2000 ek ex sadan,b20b that idles low and I have no rpm.
It has a step down with a obd1 p28 ecu.Now the harness I have now HAS been cut/tempered with.Idk the origins of it basically.I did happen to replace the harness today 8/11/18 but now has a low idle.Maybe I missed sometsomething?
The newer harness is in mint condition,unmolested off a 2000 LX 5 speed.CEL light is on but can't get it to read,I also have no cat or resi.
Help me!
Where can I begin to look for the No rpm and low idle issues?
Every answer is appreciated.
Old Aug 12, 2018 | 08:48 AM
SailorBob's Avatar
Default Re: 2000 Civic Low idle and no rpm...Help a man please!!!
I'm surprised it's even running with no RPM being displayed. Usually the rpm signal comes from the crankshaft / camshaft position sensor. Are you sure you remember to plug both back in? Also, if it's idling low but not rough, I'd make sure you plugged your IAC valve ( or whatever equivalent your car has ) back in.
Old Aug 12, 2018 | 08:56 AM
Pat_Ek1984's Avatar
I will look into it soon I get home.
Old Aug 12, 2018 | 09:01 AM
tony_2018's Avatar
Fish Twig
2000 civic's get rpm from ecu, you eliminated the obd2b ecu and are now running obd1. You'll need to source another rpm wire. your issue with low idle is now null until you get an rpm to see exactly where its idling at.
What method you used to pull code?
Old Aug 12, 2018 | 09:08 AM
Pat_Ek1984's Avatar
Can't get it to read that's another issue man smh
Old Aug 12, 2018 | 09:54 AM
tony_2018's Avatar
Fish Twig
What method did you use to "try" to read code?
Old Aug 12, 2018 | 10:45 AM
mk378's Avatar
OBD1 systems have a tach drive wire from the ICM inside the distributor. This wire only operates the tach, and maybe the ABS and SRS to tell them the engine rpm. OBDII has an output from the ECU to the tach.
The OBDII LX had a 3-wire IACV. You will need to rewire your harness to a 2-wire IACV to run with your engine and ECU.
Old Aug 12, 2018 | 11:23 AM
Pat_Ek1984's Avatar
Went down to the nearest AutoZone near me.
Old Aug 12, 2018 | 11:25 AM
Pat_Ek1984's Avatar
Christ that sounds like hell..
Any vidz or anything elsewhere else I could look up,thank you man.
Old Aug 12, 2018 | 11:26 AM
Pat_Ek1984's Avatar
Went to the closest AutoZone unfortunately.
Old Aug 12, 2018 | 11:27 AM
mk378's Avatar
Since you have an OBD1 ECU, you read codes with the OBD1 jumper wire and count the blinks method. The OBDII plug in your car no longer connects to anything. AudoZone doesn't know anything but plugging in to OBDII, even that they barely know.
Old Aug 12, 2018 | 12:57 PM
Pat_Ek1984's Avatar
Noob question..how do I get a obd1 reader?
Old Aug 13, 2018 | 07:45 AM
hondamark35's Avatar
blue connector can be found in passenger kick panel near the ECU.
Old Aug 13, 2018 | 08:39 AM
Pat_Ek1984's Avatar
Nice, I'm about to give it a try now.
​​​​​​ Gotta find a paper clip now 😂
Old Aug 13, 2018 | 10:30 AM
SailorBob's Avatar
If you want something with a bit more bells and whistles than a paper clip: https://www.hondash.net/
Old Aug 13, 2018 | 01:37 PM
tony_2018's Avatar
Fish Twig
A wire will do
Old Aug 15, 2018 | 11:25 AM
Pat_Ek1984's Avatar
My idle issue is solved. Thank you gentlemen.
Old Aug 15, 2018 | 11:44 AM
SailorBob's Avatar
So what was the problem in the end and what was the solution?
Old Aug 15, 2018 | 02:05 PM
Pat_Ek1984's Avatar
Took it to a local shop and they calibrated my TPS.
Some adjustment on the throttle cable and boom all done.
Old Aug 16, 2018 | 05:07 PM
tamboo's Avatar
10 Year Member
good diy on tps install:
https://honda-tech.com/forums/tech-m...e-tps-2947986/
cornsnake19
Jul 7, 2017 04:30 AM
edscar
May 25, 2017 07:58 PM
Hellsing032
Jun 9, 2013 10:02 PM
Interlude99
Aug 27, 2004 01:28 AM
hones
Aug 2, 2004 12:44 PM
