97 accord ecu poh-lo2 vs poh-lo2
Old Aug 11, 2018 | 01:43 PM
Bodie1234's Avatar
Default 97 accord ecu poh-lo2 vs poh-lo2
I have a 97 accord with a f22b1 vtec engine im putting a f22b non-vtech engine in will the ecu need to be changed from the poh to the poj?
Old Aug 11, 2018 | 06:30 PM
GhostAccord's Avatar
Default Re: 97 accord ecu poh-lo2 vs poh-lo2
Yes, you will need an OBD2 P0J non VTEC Accord ECU.
Old Aug 11, 2018 | 06:39 PM
Bodie1234's Avatar
Will i have to modify the harness any or will the non vtec harness match up to the poj ecu with the rest of the pre existing wiring
Old Aug 12, 2018 | 05:29 AM
What year is the F22B2 engine and harness? As long as it is OBD2 it should be plug and play!
Old Aug 12, 2018 | 07:57 AM
Bodie1234's Avatar
The f22b1 is a 97 and the non vtech f22b showed 96-97 the actual engine harnesses look completely different but both will hook up to the wiring that runs to the ecu
hondamark35
Aug 13, 2024 08:52 AM
professorman
Mar 16, 2012 07:16 AM
jereme_18
May 16, 2004 03:57 PM
Em0ne
Jan 27, 2004 02:48 PM
