Lower Timing Belt Cover part number
Old Nov 13, 2002 | 07:08 AM
webhitch's Avatar
Default Lower Timing Belt Cover part number
I called my local Acura Parts department and asked about getting a lower timeing belt coverfor a 95 GSR. They gave me part # 11810-pr3-010. Does anyone know if this is correct that sounds like it's for the 99-00 CIVIC SI or the VTEC Del Sol.
if you have the Part number please post it.
Old Nov 13, 2002 | 07:38 AM
splitime's Avatar
Default Re: Lower Timing Belt Cover part number (webhitch)
http://www.acuraautomotiveparts.net/...ING+BELT+COVER
30bucks + shipping from them. no honda part number though, just their internal part number.
Old Nov 13, 2002 | 07:44 AM
webhitch's Avatar
Default Re: Lower Timing Belt Cover part number (splitime)
yes I called them and they had the same part number but i think it is wrong cause i tried one and it didn't fit. The strange thing is that the 96 and newer GSR lower timing belt cover is a different Part number.. I was just wondering if anyone else has had this problem.
Old Nov 13, 2002 | 12:17 PM
webhitch's Avatar
Bump
Old Nov 14, 2002 | 05:53 AM
boomslang's Avatar
The lower cover is different on the newer integras because of the crank fluctuation sensor on the oil pump.
FYI: acuraautomotiveparts has some errors on their site, mostly mixing up LS/GSR/ITR parts. They are aware of this error, but they said it'll cost too much to fix.
Old Nov 14, 2002 | 06:00 AM
webhitch's Avatar
Default Re: Lower Timing Belt Cover part number (Inlinefour)
I think i found out what is going on. I have a 95 GSR block with a 96 on up Oil pump. So do you think the 96 on up lower timing belt cover will fit ??
Thanks for your help.
BTW-- Inlinefour are you in anyway accsociated with http://www.inlinefour.com ??
Old Nov 14, 2002 | 06:45 AM
boomslang's Avatar
The 96+ should fit.
I am not associated with inlinefour.com, I should change my name, I get that question often.
Old Nov 14, 2002 | 06:54 AM
webhitch's Avatar
Thanks for you help...
With the recent ripping of Inlinefour.com. You might seriously consider it. but your are cool in my book
Old Nov 14, 2002 | 07:21 AM
boomslang's Avatar
No prob.
B20VSi2000
May 11, 2016 09:45 PM
Ekhonda24
Sep 24, 2014 02:25 AM
EthanolSTi
Sep 14, 2012 10:07 AM
95LssTeg
May 26, 2006 11:40 PM
EF9Civic
Feb 6, 2004 06:20 AM
