Fixing broken LSD in U2Q7 tranny
Old Aug 8, 2018 | 01:24 AM
h1tman's Avatar
Icon4 Fixing broken LSD in U2Q7 tranny
Hello guys,
I purchased an U2Q7 gearbox from EU ATR after crash.
The problem is that the car was hit in the wheel and the part od the differential has broke off.
This part is from Torsen LSD and is impossible to find used.
Problem in visible on below picture.
The best way would be to find a good shop that would weld that and then machine it to spec but i live in Poland and finding a good shop is impossible.
If i cannot find a good welder then i will weld it myself. I have an TIG and some welding skills but lack of experience.
What filling material do you suggest? Preheat it before welding?
Any heat treatment after welding to release material stress?
Any help will be appreciated.
Old Aug 9, 2018 | 01:09 AM
h1tman's Avatar
Default Re: Fixing broken LSD in U2Q7 tranny
anyone? what could be the alloy that this part is made of ?
Old Aug 10, 2018 | 11:47 PM
Ryanthegreat1's Avatar
I would just run it. That little extra lip doesn't do anything. Bearing looks like it is still pressed on tight.
Old Aug 18, 2018 | 05:30 AM
All motor Mike's Avatar
I've personally ran ones that look worse, but I wouldn't reccomend it long term racing. Just use it and if it doesn't work well or fails you need a new one out of a t2w4, u2q7 or a p2t4 LSD trans. Others may work from various h series LSD trans but they are a tad different in some ways then the 3 lowest geared ones, I know the synchros on the 3 trans I mentioned are special and only fit them.
EG6KILIN
17
Jul 31, 2009 02:59 PM
SonicRacing
Feb 28, 2006 11:54 AM
VTECdTypS
Aug 14, 2005 08:50 PM
G2ILS
Jul 21, 2005 06:04 PM
DOHCRX
Mar 23, 2003 08:01 AM
