1992 Accord: Lost Spark from coil and plugs and power to fuel pump
Okay, I am lost at this point now and had to log back in to my old HT account. Here's the story installed new trans drove it like 4 times like 5-6 mins each time that day to get all the fluid settled. Next day starts up fine. Go to load on trailer dies. Starts up again then dies going up trailer again. This point it will not start anymore. Check spark its fine. Wouldn't start. Randomly it starts and idles then give it gas it dies. Won't start again. Now it has no spark. Left it for a few days (anger). Now I started fresh new fuel pump relay nothing. Then from there swapped coils with my other Accord. Started wouldn't rev past 1200 rpm and died never started again. Now no spark again. Put a new dist cap and rotor. Nothing. Tested for voltage at coil it's good. So replaced with new coil. No spark. Changed the icm, no spark. Now I got no spark and everything new basically. I'm lost. thanks for any help
Car: 1992 Honda Accord (external coil) f22a6
Problem: No start. No spark from coil and plugs and the fuel pump lost power.
Parts installed to try and fix: New Coil, New ICM, New fuel pump relay. And a fuel filter, it ran randomly once during all this.
Checks:
Checks:
- 12v at the coil plug
- Grounds all connected
- No power at fuel pump plug
- Fuel Pump works when jumped with power
- Plug for fuel pump relay checks out with test light
- Had an alarm I removed after all this happened . Not before, in hopes it was that.
- Fuses good unless there is like one secretly tied into everythin
babyemmasmommy
Mar 7, 2008 07:57 AM
