Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Odyssey EXL A/C
Old Aug 1, 2018 | 07:08 PM
mcbenningfield's Avatar
Default 2007 Odyssey EXL A/C
Greetings. I am new to this forum and am seeking help in regards to my van. I have had A/C work done back in March. My compressor stopped working due to the clutch relay causing to stay engaged, (parasitic draw). We replace the following:
1. Compressor, (Napa TEM)
2. Condenser, (Napa TEM)
3. Front and rear expansion valves
3. everything else that came in the compressor and component kit from Napa
4. I took the blend doors out and cleaned them and replaced the electronic grease.
5. Compressor is properly charged.
6. System was vacuumed
7. New compressor has the correct amount of oil. I asked
8. Work done by a reputable garage, (not a honda dealership).
9. PCM updated per tech bulletin for condenser fan high speed operation, (done at honda dealership).
10. New clutch relay and new fan relays.
Van siting the thermometer I placed in the vent read 69 degrees. 83 degrees outside and low humidity. 25 minute drive home and vent temp only got to 60 degrees. Should have been in the low 40's in my opinion. Been dealing with this for some time now. I am frustrated and the mechanic who did the work is frustrated. The van has been back in the shop 3 times since the initail repair with no measurable results. They evacuated the freon today and it was full. The van simply will not blow cold and the problem is either too obvious to see or more expensive than I can afford at this point. Can anyone off any insight? Thanks in advance.
Old Aug 2, 2018 | 01:06 AM
holmesnmanny's Avatar
Default Re: 2007 Odyssey EXL A/C
making sure the ac is off, parked in the shade, with the climate control on full blue, and the car completely warmed up, does the air come out warm when it should be cool ?
TonyI
Apr 16, 2018 08:00 PM
CR-VOwner
Honda CR-V & Element
Sep 6, 2014 09:59 AM
thinkskater007
114
Sep 3, 2012 06:36 PM
freestyler_
32
Jul 3, 2009 09:23 AM
old man honda
Apr 14, 2006 07:01 AM
