H22 swapped 6th gen accord running rich
Old Jul 31, 2018 | 02:50 PM
Mastgohn's Avatar
Default H22 swapped 6th gen accord running rich
Hello, I have a 98 accord ex sedan (manual) that I recently swapped an h22a into. I rebuilt everything to stock specs and the internals are almost completely stock. The only difference was that I installed a set of pistons to bump the compression up to 11:1. I have followed the h22 swap thread that drift made almost to the letter. I even took the harness out and chased every wire.
Now here is my problem, the car runs very rich. I have installed an adjustable FPR and set it to stock specs and nothing has changed. The car reeks of fuel when running and it sounds cammed for some reason. I've tried everything I could think of, from stock injectors to all new ignition parts. I am running a 37820-p13-n50 ecu. Does anyone have any suggestions? Any help would be greatly appreciated.
Old Aug 1, 2018 | 01:06 AM
holmesnmanny's Avatar
Default Re: H22 swapped 6th gen accord running rich
depending on which injectors you are running is what determines if you need a resistor box
low impedance needs a resistor box while high impedance needs no resistor box
an exhaust leak will cause you to run rich too as it will see the outside unmetered oxygen in the air leaking into the exhaust as needing to bump up the fuel
Old Aug 1, 2018 | 10:23 AM
Mastgohn's Avatar
I wired a set of resistors to make by own resistor box, since they are obd1 injectors. My next step is the exhaust, so I need to try to see if that helps anything. Thank you.
more3688
May 31, 2013 07:45 PM
more3688
Mar 10, 2010 02:57 PM
Hatchls1
Dec 16, 2008 06:00 AM
310tpi
Apr 25, 2007 08:35 AM
93accordsleeper
Oct 8, 2006 05:30 PM
