Acura RL 4 Pot Calipers On Integra
Old Jul 30, 2018 | 10:23 AM
DC5key's Avatar
Default Acura RL 4 Pot Calipers On Integra
Is it possible to install the rl 4 pot calipers onto the dc2 integra?
Old Jul 30, 2018 | 06:58 PM
SpiderX1016's Avatar
Default Re: Acura RL 4 Pot Calipers On Integra
Yeah it's possible. Info is out there, not worth it imo though. Would rather do the ITR upgrade or Wilwoods.
Old Jul 31, 2018 | 08:39 AM
MotorMouth93's Avatar
10 Year Member
People have done it before, but adapter brackets are difficult to find and expensive.
You also mess up the brake balance, the front/rear piston size and proportioning valve were designed with a certain bias in mind, if you start changing the surface area of the brake pistons then you change the braking bias. Without recalibrating you will likely see reduced brake performance.
raverx3m
Nov 13, 2010 12:30 AM
cast98integra
Jul 30, 2008 01:26 PM
92integraVTECgsr
Dec 21, 2004 03:31 PM
joeski
Oct 23, 2003 10:09 PM
