Installing AEM CAI on a DX
Old Nov 13, 2002 | 04:23 AM
Cowtit's Avatar
Default Installing AEM CAI on a DX
Can anyone give me some tips/pointers/what to watch for cuz I'm going to install it tonight. Any special tools I need? I have 97 Civic DX. Before you tell me "Do a search NOOB!!", I already did, and all the results were for Preludes. Thx, Lata.
Old Nov 13, 2002 | 04:56 AM
STEALTHMODECOUPE's Avatar
Default Re: Installing AEM CAI on a DX (Cowtit)
the only tool youll need is a screwdriver and a socket for the one bolt the intake uses to clamp onto the car to..very easy install goodluck
Old Nov 13, 2002 | 05:07 AM
Cowtit's Avatar
Won't I need to cut a hole in the fenderwell?
Old Nov 13, 2002 | 05:39 AM
Milano_EH3's Avatar
Huh?! Why would you have to cut anything? Didn't it come with instructions? My suggestion is turn it upside down, cut a hole in the hood and have it stick out from there.
I don't really mean to be a dick ::chuckle:: but, just look under your hood and it should be obvious what to do.
[Modified by Milano_EH3, 9:49 AM 11/13/2002]
Old Nov 13, 2002 | 05:40 AM
Default Re: Installing AEM CAI on a DX (Milano_EH3)
damn yO thats a good idea..get some mad cold air like that..im sure you dont have to cut anything that would be dumb on AEMs part
Old Nov 13, 2002 | 07:20 AM
splitime's Avatar
on some of the 96+ people have had to cut out the hole it goes through in the fender. Its a stamped circle, you can use whatever to trim it if your car doesnt have the hole already.
Old Nov 13, 2002 | 08:12 AM
Default Re: Installing AEM CAI on a DX (splitime)
i dont think so
Old Nov 13, 2002 | 08:14 AM
Paranoid Android's Avatar
dude intake is the easiest thing to install, it takes approximately 8 minutes.
its very obvious and if you still have trouble, invest in a helms, you will need it later for much bigger projects
Old Nov 13, 2002 | 08:15 AM
hey splitime your names dave right..if so we met at the BBQ in chi-town
adaM
Old Nov 13, 2002 | 08:32 AM
dwnthehatch's Avatar
Default It's simple
Make sure the motor is cold. You wil have to remove and replace the antifreeze line to the throttle body. Remember to reset your ecu once you are done.
Old Nov 13, 2002 | 08:36 AM
Default Hole
i dont think so
Sorry dude he is right. I installed three AEM intakes on three different DX hatchbacks (99-00). All required me to cut out a circle in the inner fender. The hole is not there like in a ex because the DX has a different style intake that doesn't have the resonator in the fender well.
Old Nov 13, 2002 | 08:39 AM
Default Re: Hole (dwnthehatch)
i dont think so
on me..sorry i was just thinking about the EX's..ive installed a few on them and didnt have to cut anything..thanks for the clearup though
Old Nov 13, 2002 | 09:49 AM
EVIL Hx Coupe's Avatar
Default Re: Hole
My friend has a Dx and his intake goes through the side of the fender well. He doesnt have a hole.....
Old Nov 13, 2002 | 09:55 AM
Cowtit's Avatar
Default Re: It's simple (dwnthehatch)
How do you reset the ecu? Unhook the battery, right?
Old Nov 13, 2002 | 09:56 AM
Default Re: It's simple (Cowtit)
[QUOTE]
yes thats all you need to do..let it sit unplugged for about 10-15 minutes and your good to go
Old Nov 13, 2002 | 10:03 AM
Cowtit's Avatar
What did you use to cut the hole in the three DX's you did?
Old Nov 13, 2002 | 07:03 PM
scttydb411's Avatar
i didn't have to cut anything on mine. unless the coupe and hb are different. instead of having to go through where the cut-through is on other models it curves around the entire well and drops the filter right behind the corner of the bumper. very easy straight forward install.
Old Nov 13, 2002 | 07:13 PM
FifthGearOnline's Avatar
Default Re: Installing AEM CAI on a DX (scttydb411)
these are pics of the aem CAI on my 99 DX
you do NOT!!!! have to cut anything.
the only hard thing to do is get the stock filter unit off....and thats because the band holding it on is a BITCH to get off! (The bolt faces the back of the car)
Old Nov 14, 2002 | 11:05 AM
dcsports's Avatar
maybe u should not hook it up get a swap DX bah
jt61583
Honda Civic (2006 - 2015)
Mar 16, 2007 09:34 AM
dLo GSR-stolen-now-WRX
Jun 18, 2005 04:51 PM
AlekSir
19
Mar 21, 2005 03:35 PM
MugenPoweredLude
Nov 30, 2002 12:54 AM
stoopid215
Oct 28, 2002 08:02 PM
