Voltage drop issues
Old Jul 30, 2018 | 06:09 AM
00GreenRanger's Avatar
Default Voltage drop issues
As the title says, I believe I am experiencing some voltage issues.
Specs on the car: 1999 civic SI, JDM B18C motor, 95 GSR computer, hondata s300, GSR alternator (brand new), and a odyssey pc680 battery (2 months old).
Symptoms: If I have the air blowing and my music on at the same time, the check engine light flickers. It's not a flash but a flicker and it is not fully lit up either. For example, the light gets brighter when the bass hits and then dims/goes away when it doesn't. If I turn the air off, the light stops flickering and goes away. This has been occurring more and more so I'm trying to get to the bottom of it.
When I start the car in the morning there is no CEL and it starts fine. After about 5 mins of driving down the highway it begins to act up. It doesn't effect the way the car drives but I see this as a problem.
Has anyone experienced this or have any idea what I should be looking into?
Thanks!
Old Aug 1, 2018 | 09:45 AM
Relic1's Avatar
Default Re: Voltage drop issues
music - sub? amp(s)? or just the radio powering speakers?
have you checked your ground wires?
what adapters did you use for the battery?
do you have a volt meter?
Old Aug 1, 2018 | 08:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Small lightweight race style batteries are not designed to support high drain accessories such as high-current amplifiers and A/C coil/compressors. Get a normal battery and see if your problem goes away. Race cars don't have A/C or big stereo systems... and street cars don't need to save fifteen or twenty pounds in total vehicle weight by switching to a low reserve capacity battery.
Bleakened
Feb 7, 2015 09:08 AM
chadtheman
Honda Civic (2001 - 2005)
Jan 24, 2013 12:24 PM
vegas hoe
Transmission & Drivetrain
Jun 3, 2009 02:12 PM
zcivicz
Dec 5, 2005 10:44 AM
