Idle Surge
Old Jul 29, 2018 | 07:44 AM
Robbie Spangler's Avatar
Default Idle Surge
Hey guys, looking for some help. I have a 97 Civic with a D16Y8 motor. In Park after start up the engine idles at about 1200 rpm for a few minutes then it will start surging up to about 1800-2000rpm. Turn the ac on and the surge goes away. Won’t surge in reverse or drive. Watch the video, let me know what you think. Thank you!!
Already got all of the air out of the cooling system, played with the adjusting screw. I’ve searched for hours and can’t find the cause.
Old Jul 30, 2018 | 07:52 AM
Kevs02Accord's Avatar
Default Re: Idle Surge
Dirty / clogged IACV is my guess.
Old Jul 30, 2018 | 01:11 PM
0c00l's Avatar
What Kevs said and you can check this out if you haven't.
Old Jul 30, 2018 | 03:51 PM
tony_2018's Avatar
Fish Twig
Why did this start? Why did you have to bleed? What did you adjust, what screw?
Old Jul 30, 2018 | 05:50 PM
Tony, we purchased the car not running. It was missing a bunch of stuff on the top of the motor. After 4 or 5 trips to pick and pull it’s running. I’ve been searching D16y8 idle surge and one guy said air pockets in the cooling system can cause a surge. There is an idle adjustment screw that just raises or lowers idle rpm.
Old Jul 30, 2018 | 06:19 PM
Forgive my ignorance but where is the idle air control valve?
Old Jul 31, 2018 | 08:48 AM
Its under the throttle body. I found it easiest to disconnect the air box at the TB, then take the whole TB off, then take the IACV off, install is reverse. Also, you will have to purge air from the coolant as there are lines going to the IACV.
Edit; I just cleaned mine out, either not very good, or it was inevitable, but its giving me issues again, I bought a new oem IACV off ebay for under 100.
valoskater420
Mar 28, 2014 12:12 PM
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
v8killaz
Nov 23, 2011 08:19 AM
ham
Jan 19, 2011 06:34 PM
ham
Engine Management and Tuning
Jan 19, 2011 05:28 PM
