Boring out throttle bodies.
Old Nov 13, 2002 | 02:29 AM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
Default Boring out throttle bodies.
How much does boreing throttle bodies usually cost? What's the max you can bore it out to?
Say a have a 60mm TB, what's the max that it can be bored?
Old Nov 13, 2002 | 02:39 AM
xpsonic's Avatar
Default Re: Boring out throttle bodies. (VitaminB20)
dunno how much it costs but i did mines by myself....felt a small gain but its well worth it if you just do it yourself....if a shop does it, it will be way too much. just letting u know
Old Nov 13, 2002 | 05:43 AM
ExospeedAMcrx's Avatar
Default Re: Boring out throttle bodies. (xpsonic)
you can bore it out yourself but the best way is to get it done and with a new matching plate to go with it.
Old Nov 13, 2002 | 11:12 AM
VitaminB20's Avatar
Default Re: Boring out throttle bodies. (exospeedAMcrx)
How do you DIY? Are there any how to's? Any would be appreciated.
Old Nov 17, 2002 | 10:15 PM
EVOCELICA's Avatar
New User
boring a throttle body requires a new butterfly plate, so doing it yourself will be hard to acomplish. I believe the biggest you can get a stock 60mm is to 64mm anything bigger than that and you need to get a custom jobber.
RPM service makes them up to 70mm I believe. They can be bought from JDMhondaparts.com and Ericks racing I believe the cost is around $350 - $400 If all you want is your stock throttle body bored to 64mm RC engineering and JG engine dynamics do it for roughly around $150 - $200
Old Nov 18, 2002 | 09:59 AM
WAFFLES's Avatar
Default Re: Boring out throttle bodies. (EVOCELICA)
Also something to consider is that a bigger TB will sometimes hurt performance, like if it is on a stock b16 intake manifold. And when you bore it is wise to change butterflies out for a larger unit.
Since I am using the stock b16 i.m., I plan on taper boring the tb to 62mm. I know I probably will not see any hp gains, but throttle response should improve a bit. To do it yourself you can get a honing tool, from any tool shop. Attach to a drill and then bore out. However, I'm not sure where you can buy larger butterflies.
Old Nov 23, 2002 | 05:37 PM
owen_the_soyboy's Avatar
Default Re: Boring out throttle bodies. (WAFFLES)
FATninja19
Jun 26, 2006 10:51 PM
snoochtodanooch
Dec 27, 2004 05:46 AM
koy
Jun 22, 2002 02:12 PM
GSxRated
May 9, 2002 04:57 PM
onyx00
Jun 25, 2001 05:55 AM
