Engine harness compatibility: Del Sol
Okay so this is my first post on honda-tech so bear with me, i have always wanted a honda project so about a month ago i finally went and got m =y first project. purchased a b20z swapped 96 del sol that wasnt running due to electrical problems is all the guy knew. we (a friend and i) started tearing things apart looking for the causes, swapped ecu and main relay but for some reason it kept blowing the ecu fuse in the underhood fuse box, so i ended up just pulling the wiring harness all the way through. i guess my question is, is there any other harness i can use to put in the del sol? its a 96 so its obd2 but the 96-97 obd2 del sols are hard to find here in the california valley. is there a harness i can use out of any other car? any info would seriously be appreciated! Thanks in advance
stiffinEK
Nov 22, 2009 04:49 AM
drugyungrage1986
Jun 20, 2007 08:41 AM
