h22A In 97 Prelude What Harness And what to do about CPS
so i have a 97 prelude and i swapped a h22A1 into it the sensor by the crank pulley is not on the A1 and the OBD1 distributor has 8 wires where the harness has only 4 how do i wire this up or can i just use a obd1 harness also do i need to change the oil pump from A4 to A1 or is it even possible to do so i can run the sensor all help is greatly appreciated! thanks!
I believe the OBD1 dist has a sensor that does the same as the crank sensor on the ODBII A4 motor so you have to connect the wires going to the oil pump to the distributor.
infernal21
Aug 8, 2006 06:07 PM
infernal21
Aug 8, 2006 01:58 PM
Need Help Please!!!, OBD1 JDM H22A swap into 97 prelude and didn't swap the oil pump for CKP sensor.
SirRevvs
Jun 13, 2006 06:06 PM
