Help with timing!!
I recently replaced the head gasket in my 95 civic. Since then ive had a crank but no start issue. I found my TDC by aligning the white mark on my crankshaft with the oil pump pointer. Yet, still no start. Upon opening my distributor the rotor was facing the number 4 plug after attempting to turn motor over. Can somebody please help me with this . Crankshaft pulley was replaced over a year ago by a shop due to bolt having to be drilled out . Im unsure if the camshaft and crank might be off when it comes to lining up for TDC . Im just can't think of what else this could be. And yes, car ran before head replacement.thank you for the help.
cam gears will have markings which will be at 9 o'clock and 3 o'clock (wont be dead straight but lines up with the back on the timing cover) the gears might also have "up" and a arrow on it. The cams may also have a hole in the first cam cap so when you line it up you can put in a pin or skinny bolt or screw driver in so everything is lined up.
Take pictures for us if you have problems
Lets ask some clarifying questions here....
Did your wife turn the cam shaft with the timing belt off?
If yes, then you will have to take the timing belt off to reset your mechanical timing and then re-install the timing belt.
Second and probably more importantly, do you know how to set mechanical timing and do a timing belt job?
Thirdly, do you have a Factory Service Manual (helms manual) for your car?
I need another way to verify that my cam timing is correct bc as I said I do believe the lines are giving me a false TDC . Thanks for all your help . And yes this is the 6th time I've had my timing belt off . Im just ready to get it right so I can have my car on the road again. The head gasket replacement wasn't even though it complicated to any degree but this part has been my downfall .
Take pictures of the cam gears. And if you have taken the cam gears off they will only go on one way. Don't worry about the distributor leave it out of the equation.
Pictures are worth millions in this situation for us too help you.
Cam lobes are downward on cylinder 2 which cylinder one is next in the firing order . The only aspect I'm concerned about with the distributor is the keyway . If it's up and down or side to side bc in that case I think I have it but the lines definitely don't line up.
To rotate the cam it's best to rotate the crank 1/4 turn to mid shift the pistons, then you can rotate the cam freely. Once done with cam, rotate the crank back to TDC (sole white mark in sites) to install timing belt.
The D15B7 cam gear has the word Up on it as well as a left and right mark on the edge that should align with the top of the head when in TDC position.
I don't remember off hand but I believe the D16Z6 cam is the same way.
Actually pulling up the FSM. D15B7/D15B8, Up mark and side marks level with top of head. D16Z6, Up mark and bottom mark with bottom pointer. D15Z1, Up mark and side marks use arrows on back timing cover.
D15B7 by the looks, you have the cam gear 180 out. The UP stamp appears to be at the bottom behind the hose in your picture. It is supposed to be above the level of the head in the "up" position.
Please see my previous post for FSM specific details as well as proper concerns that should be taken when turning cam shaft.
Ok here's my update . I was checking for spark and there was none so I looked over my fuses and 15a ecu fuse blown . Replaced the fuse. Now I'm sitting in my car afraid to turn it over in case it is out of time. Hash marks on cam gear are lined up with block. My question is about the cam lobes on exhaust side . They are tilted downwards. What should their appearance and position be when I am TDC cylinder 1?
At TDC1, all 4 valves of cylinder 1 should be closed. The rocker arms should be slightly slack.
You're not going to cause any (further) damage now that the ignition works. The valves would have already crashed whether or not the sparks fire.
so show us where the cam gear is at now...
