Obd2 integra into dual point civic
Old Jul 23, 2018 | 07:08 PM
clicky79's Avatar
5 Year Member
Default Obd2 integra into dual point civic
Through many hours of research i believe the easiest way to make this work is to convert my car to multi point and convert the motor to 0bd1, i read somewhere that obd1 injectors dont need the resistor box likes obd0 is that true for 0bd2?
Old Jul 24, 2018 | 09:24 AM
KandyCRX's Avatar
Default Re: Obd2 integra into dual point civic
Yep i just put 00 itr engine in my CRX. Need a jumper harness for the ecu. Remove the injector box and soldier the wires together. Upgrade the oem harness to mpfi then to obd1. Soldier in the distro plugs off the teg harness or get a jumper.
Old Jul 24, 2018 | 11:47 AM
clicky79's Avatar
5 Year Member
Do you have any brand recommendations for the ecu conversion harness?
Old Jul 24, 2018 | 11:51 AM
dc2_rick's Avatar
a cheap ebay one should work
Old Jul 24, 2018 | 03:22 PM
jlicrx's Avatar
you get what you pay for - buy a cheap harness, you get a cheap harness that might work or may not
https://www.boomslang.com/obd0-to-ob...2&trans=Manual
has all of the wiring incorporated into the harness for the DPFI to MPFI conversion - has VTEC wiring in the harness
instructions can be seen in the above link
Old Aug 22, 2018 | 04:53 PM
clicky79's Avatar
5 Year Member
So you had a hydro clutch, what motor mounts did you use?? i had purchased a car that had a sketchy b18 in it with a cable trans and it had these cheap motor mounts that worked on it, but when i got the b18 out of my 96 integra with a hydro non of them seemed to line up and the only mounts i found online are 300 dollar billet aluminum ones.
pnapolitano29
Nov 26, 2014 07:30 AM
known
Oct 14, 2014 08:18 AM
jdmekrobot
Mar 13, 2008 12:13 AM
civicex442
Dec 2, 2007 07:38 AM
ForceFed Coupe
Jan 21, 2004 07:18 PM
