car bogging randomly/ wont start
Old Jul 23, 2018 | 11:08 AM
editingideas's Avatar
Default car bogging randomly/ wont start
i have a 1998 honda civic the car randomly started to bog a little while i was driving then it went away , then around high rpms it would start bogging again but sometimes it would bog sometimes it wouldnt at high rpms eventually it will shut off while driving but i could feather the gas to keep it running, now it wont turn over at all but the belts move.
Old Jul 23, 2018 | 04:14 PM
Megalodong's Avatar
Default Re: car bogging randomly/ wont start
Intermittent issues can be hard to diagnose. An obd2 live data scanner would be handy to diagnose the bogging as issue as it happens. Can buy them cheap on amazon:
Amazon Amazon
Other than that try checking spark quality. Inspect air filter, Clean the throttle body. The distributor's coil (ICM) and/or igniter can cause bogging issue intermittently when they are failing (but not completely failed). They can be ohm's tested but the best test is to check the spark gap using a a long screwdriver to ground. A weak coil can often completely fail when live tested this way but that'sa good thing in this case because it indicates it needs to be replaced anyway. Read reply #4 in this link: https://www.civicforums.com/forums/2...-no-spark.html Ezone is a long time Honda dealership mechanic.
Old Jul 25, 2018 | 11:33 PM
Race.N.Dynamics's Avatar
map sensor?
Jakester9500
13
Aug 12, 2017 03:48 PM
Michael Torres
Honda Civic (2001 - 2005)
Mar 1, 2016 04:29 PM
nmaese01
Mar 14, 2014 11:17 PM
EGandDArida
Aug 24, 2009 02:34 PM
GSRWSU
Aug 11, 2009 10:44 AM
