1991 Honda Accord Wagon 2.2 Engine Stuttering
Old Jul 21, 2018 | 09:18 AM
Rickweath's Avatar
Default 1991 Honda Accord Wagon 2.2 Engine Stuttering
Hi Folks,
For the longest time I have had a problem when taking my Honda wagon on the highway. The check engine light comes on after only a few short minutes above 70 km/hr - 40mi/hr. It does not come on around town and the engine runs fine. The OBD code is 43 which is "fuel system problem." I have cleaned, tested and or replaced all of the obvious fuel system components and even removed the ports and cleaned the EGR manifold. Lately if I try to drive above city speeds it starts to stutter and buck slightly and will not accelerate no matter how much I push on the gas pedal. After a short time the check engine light comes on and everything clears itself and the engine power and rpm return and all is normal again even at highway speeds. Any ideas??
Regards,
Rickweath
Victoria BC
Old Jul 21, 2018 | 01:53 PM
holmesnmanny's Avatar
Default Re: 1991 Honda Accord Wagon 2.2 Engine Stuttering
Normally the first thing to think of when this code comes up is to replace would be the oxygen sensor with a Denso unit.
Old Jul 22, 2018 | 02:12 PM
Rickweath's Avatar
Hi, much thanks for the info. I have already replaced the sensor around 6 months ago but I am not sure it was the Denso brand. I will get it checked again. I am also wondering if it might be a sensor in the mass air sensor unit. About the only other thing I havent looked at is the fuel return valve sensor.
rick
Old Jul 23, 2018 | 01:47 AM
This is a really pesky code. I would probably pick up another ecu from the junkyard and if that doesn't fix it, take it back and swap it out for another set of injectors from a 90 - 93 accord.
You can also check for an exhaust leak by seafoaming on a cold start when the engine rpm is automatically up at 1500 rpms, look for white smoke coming out anywhere from the exhaust manifold to the oxygen sensor.
Old Jul 23, 2018 | 08:34 AM
Rickweath's Avatar
Yep, you are right. 43 code is very ambiguous and can mean many things. Okay, I will check O2 sensor, then look at the ECU. The injectors seem to be fine because they work at all times at any speed. The idle is smooth and high speed driving is really good/problem free as long as the check engine light comes on. Fuel pressure is normal so no problem with pump. Sure could be the ECU. Soon I am going to give up on this whole problem and take it to my favorite mechanic. At least he will have some proper diagnostic tools to check on O2 voltage levels etc. Thanks again for your advice and perspective.
Rick
Ankit Poonia
Feb 21, 2015 05:01 AM
gondwana1
Aug 24, 2012 05:45 AM
1997accordSE
Feb 11, 2012 07:58 PM
zguan
Honda Civic (2001 - 2005)
Feb 23, 2011 01:29 PM
Hondalina
Dec 13, 2010 02:39 PM
