Obd1 swap cranks no start no check engine light
Old Jul 18, 2018 | 01:25 PM
toxictom's Avatar
Default Obd1 swap cranks no start no check engine light
So I just obd1 swapped my 90 hatch. The car cranks but won't start, it dosent flash a check engine light even when you first turn the car on. It does have the fuel pump priming. And I am running a b series dizzy. Any idea what could cause the check engine light not to flash? Bad ecu?
Old Jul 18, 2018 | 02:24 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Obd1 swap cranks no start no check engine light
Did you do MPFI OBD0 to MPFI OBD1, or did you do DPFI OBD0 to MPFI OBD1?
Sounds like a wiring issue. Get a wiring diagram and a multi-meter and start probing.
ef9allday
Mar 14, 2012 11:12 PM
dohc15
Jan 10, 2012 11:17 AM
gsr converters
Dec 16, 2007 03:38 PM
Audipwr1
Jun 3, 2003 08:26 AM
